This boat was gifted to me. It hasn't been ran since 2006. I changed the spark plugs and fuel bulb and it started right up. (With muffs on of course). There isnt but a trickle of water coming out of the pee hole. I can blow air through it so I know there isnt a blockage. Im assuming I need to change the impeller and will. My question is should I also change the water pump? I would normally just change it but my marina wants $100 for the kit or $35 just for impeller and gaskets. Ive looked on line and not even sure of what part number I would need. The motors serial number is 6150632. Thanks!
