Hi,
I have a Mercury 35 EL 2 stroke engine from 1985. Have trouble getting the gear housing off to replace the impeller. Everything is properly loosened but it opens only a few centimeters. Have tried as everyone else with the same problem using wedges etc.. The only thing that remains to check are the drive shaft so it?s not rusted as it can be on old Mercs. Im going to also loosen the gear shaft but to access it I have to remove the engine block.
I need an exploded diagram or manual that shows exactly how to get the engine block off. Have loosened all the screws I can see but apparently I missed something beacuse it wont come off.
Do someone have a full exploded manual or only a manual for this engine? Have been searching online for a week now with no results
