Re: 1984 75hp mercury 4 cyl stator replacement
your in the I/O section but that s ok.
remove crackshaft nut, use proper puller to remove flywheel. remove mounting bolts R/R stator, reassemble NO BIG HAMMERS
If you dont have the correct puller, loosen cranknut to top of threads,but do not remove.
carefully raise up the flywheel and using a wood block give the nut a sharo tap, this shouold free the flywheel DO NOT LOSE THE WOODRUFF KEY
you`ll find your manual in here
http://boatinfo.no/lib/library.html
