kbradley1983
- Aug 3, 2013
- 5
Boat: 1982 Lowe Bass Catcher pro
Motor: 1974 Mercury 500 2 stroke 4 Cylinder
SN: 4075319
This is my first post so please excuse any errors in etiquette.
I've recently purchased the boat above. There was water draining from the lower unit when I replaced the gear lube. In addition, after replacing the lube I've noticed gear lube leaking from the lower unit. I suspect I need to replace the seals in the lower unit, but I'm having trouble locating the seal kit for the serial number. Every kit I find says for SN 4357640 & up. I'm beginning to the kit is discontinued. It is possible to buy a kit or will I have to try and source each part individually? Thanks in advance.
KB
SN: 4075319
KB
