Re: Mercury 90 hp start issue
Engine start wire should be yellow with red stripe.....is on my 90 anyway. That wire supplies 12v to energize the starting solenoid. 12v is supplied through the ignition switch in the start position from the red 12v wire connected to the switch from the fuse. Since you know that the starting solenoid and wiring harness wiring function properly, my thought is that you have a short inside your ignition switch. It happens, especially on older well used, possibly water infiltrated switches.
Mark
