Imjus4u2nv
- Jun 10, 2013
- 57
I own the following engine:
MERCURY - ( 90 H.P. (1986 ))
Serial No: 0A968445 Model No: 1090726
After some overheating issues last year (which I believe have been solved by rebuilding the carbs and other repairs), I am attempting to install a temp gauge AND a water pressure gauge.
My engine has pre-tapped hole that goes into the directly into and through the water jacket (I believe by the #4 cylinder).
I bought a pressure kit that fits in this hole and it works - just plug and play.
My issue is with the temp gauge. I bought a temp gauge kit, with flat mount sender from faria. I cant seem to find a place to mount the flat mount sender anywhere. Does anyone know if I can install a flat mount sender somewhere else?
I also got a z-bracket from my mechanic that seems like it will be able to fit better, however I will need to use a 1/8th regular sender and not sure if it will work with my gauge and how I can tell what gauges the sender will work with.
For both options I can just remove a bolt from the water cover jacket cover and mount the sender- however then the sender will be touching the water jacket? Is this what it should be touching?
I know my engine will never give me a perfect or accurate engine temp, but I would like to have the gauge work, and I can always mark the gauge with "normal" running temp and note when it is running hot.
Any help, as always, is greatly appreciated!
