Re: Water on bottom spark plug and the oil on the treads look milky?
It is a Mariner engine, made by Yamaha for Mariner:
25 M 695-000101 - 695-003445 1979
Parts List for s/ns 695-000101 thru 695-023895:
MARINER 25 - Mercury, Mercruiser, Force, etc. Parts Lookup
See lower crank seals, item 13 under CRANKSHAFT AND PISTON.
Mariner outboards are identified by engine
serial number. This number is stamped on a
plate riveted to the transom clamp. It is also
stamped on a welch plug installed on the
power head (Figure 1). Exact location of the
transom clamp plate and welch plug varies
according to model.
I am working on getting you the condensed version of the Clymer manual which is buried under a larger file. Can you PM me an email address that I can send information to you?
Gerry
