Yesterday the motor started (little hard to start), ran good for about 1-2 minutes then kept dying. I took the VST off cleaned it up, was dirty, put it all back together right. Now motor gets the beep when turning on key, and then BEEPS ONE time when I crank motor. Motor will not start. I have replaced, water pump, Spark plugs, All Filters. No Blown Fuses. I get pressure and gas that comes out of the little pressure tab (that looks like a tire nozzle). Primer Bulb stays hard. When I turn key to on, the fuel pump kicks on and off. Hoping it is not the High Pressure Pump in the VST. But looks like it might be.....But Does anybody know what that One Beep means when I try starting it. S/N 1B362085
Thanks
Thanks
