i have a 1979 mercury 115hp 1150, on a 24 ft pontoon. I bought the motor off my cousin. He had it on a ski boat that had hull damage. I have been on the boat more times than i can count and i know the motor runs great. When i bought this pontoon it had a 1971 115hp mercury. The motor would turn over but not fire. I swapped the 71 out for the 79. I used the controls that were on the boat. The motor will not turn over with the key. Its like there is no battery hooked up. On the old motor(the 71) it would turn over fine and when i pushed the choke button i would hear a click. Now with the new motor (the 79) it will not turn over nor click when the choke button is pushed. I can jump the solenoid and it turns over and fires. I believe the ski boat this motor came off of had a fuse pannel in it, could that be the problem? Is there fuseable links on the motor anywhere? It also has power trim on the motor but no buttons on the old controls im using (the controls that came on the boat with the 71). The wiring on the controls off the ski boat is in bad shape so i never tried to use thoes contols. I also unplugged the wiring from the new motor and back into the old motor and the old motor still turns over.
