fishon1213
- Aug 10, 2009
- 80
I have a mercury 200 20hp outboard that I believe is a 1978. The s/n is 4821964. The motor is electric start but the starter is not turning the motor over completely. I have tried two different batteries with the same results. The starter button also does not work and I suspect that someone did not wire the solenoid correctly, it is not original. So I am jumping the two large terminals on the solenoid to attempt to start the motor with no luck. It turns over but slow.
So I am not getting the voltage I need or maybe the starter is weak. Can anyone help me in how to further diagnose this problem? Also how should the solenoid be wired? It has two large terminals and two small terminals.
I would also like to add pull start to this motor as it does not have the flywheel that you can put a rope on in a fix. What years recoil assembly will work?
Thanks, Al
Thanks, Al
