Re: 1982 black max 150 trim problem
So what about tilt fluid? Do i just put the oil in that motor? And what about the bleeding?
A) tilt /trim fulid is fine along with SAE 10W30 or ATF....
B) just fill the pump motor....
C) no bleeding as self bleeding.....
And when putting oil do i need to have motor trimmed all the way up?
The proper way to fill:
1) place engine full down
2) remove fill/vent screw and oil should be on full mark on dipstick, if not add to full mark. Do not overfill!!
3) Reinstall fill /vent screw and back out 1-1/2 turns from seated
4) Trim engine up and if stops from lack of fluid,remove screw and only add to add line on dipstick and repeat till engine reaches full up.
5) Repeat step 4 for down...
6) Bleed remaining air from system by trimming full up/down several cycles and checking oil level each cycle and add oil in needed.
7)When finished tighten fill/vent screw to light seat and back out 1-1/2 to vent oil reservoir
8) Your done!!!
