So I am completely new to outboards and I have been working on this older 60hp for my bass boat. When I removed the flywheel in order to replace stator and trigger, I pulled all of the smaller bolts and the large center bolt. I did not mark exactly how the flywheel lined up, and about 20 minutes later I realized that I may have screwed myself. I have put everything back together and finally got the motor started. How can I tell if my timing is going to be messed up? and If it is messed up, How can I fix it? Thanks in advance
oh and btw, the serial # is A140948 1986 Merc 60hp
