turkey slayer
- Mar 27, 2014
- 3
A list of what has happened since August of last year. Stator and voltage regulator replaced, stator went out again had it replaced, took boat out in Jan after getting it back the key shatters under fly wheel, I take it back to shop they replace it and put motor back in time. I get home put my ears on and try to crank motor it will not start doesn't even try to just spins over? I wait an hour and half try it again and it eventually starts, it acted as if it was flooded out. I started the motor for the next two days without any problems. I go to the lake last week put it in the water and it does the same thing just spins over. I tryed it several more times while trolling around just spins over. The next day I go out put the ears on it and it starts right up, it has started up everytime the last two days. It seems like when I haul it is when it doesn't start? compression is good, put new plugs new fuel filter plus all the above from the so called boat mechanic shop. I think this is a fuel issue but I am not a mechanic any help would be appreciated.
Thank you
Thank you
