buzzcatcher
- Sep 6, 2011
- 9
Hello there. I am somewhat new to this site and new to outbaord motors. I purchased a used 2003 4hp 4stroke mercury. Everything was running fine. When I brought it home, I did a tune up with new plugs, new oil, new impeller/waterpump, and rebuild carb with carb kit. Push pull and it fired right up. The only way for me to start the motor is if I pull the choke all the way out and start it. Once I push in the choke the engine dies. Regardless if the engine is warm or cold, it will never start if the choke is pushed in. The unit has a built-in internal gas tank and I did remove the cap for proper venting (air) when I would start the engine. Do you think that I installed the carb wrong? Any advice on what could be the problem? Please help a newb out. lol thank you very much in advance.
