Mader12345
- Mar 13, 2014
- 18
I have a 125 hp mercury outboard. Year 2000. Serial 0t088785.
I just did link and sync per the service manual for this engine, including setting the stop screw so that the butterflies in the carbs open completely at full throttle. I did this procedure with the throttle cable not attached to the engine. When I attached the throttle cable and advance the throttle at the control box the throttle cable does not "travel" enough to allow the carbs to open up completely. It needs another half in of movement or so.
Both the throttle cable and the control box were replaced with aftermarket (teleflex I believe) a couple of years ago. I've never really gotten wot out of the this engine.
There is no adjustment at the control box to increase cable travel as far as I can tell. And the adjustment to the spinning plastic nut on the engine side does not do anything to increase travel.
At a loss.
At a loss.
