The water pump base is flat on the bottom while the housing surface on which it rests has three slightly raised areas between 1/32" - 1/16" thick around or near the three stud bolts. The gasket that goes between the pump and the housing surface is not thick enough to fill the void created by the uneven surface. I can't imagine the function of the raised areas. Can anyone tell me if this is a problem or if I should just bolt the pump down tight and forget about it?
