Re: 1989 Mercury 115hp won't start
The motor should have a fuel enrichment valve that when the Ing. key is pushed in, it pulls a solenoid valve that lets raw fuel be put into the crank case so the motor will start. It might be that the solenoid is bad or that the wire from the Ing.Switch to the solenoid is bad. Have some one, with the safety kill switch pulled, push in on the switch and see if the enrichment valve is working. JMO
Oldman570
