Re: How do I take the drive shaft out of a Mercury 402 40 hp
Remove the water pump housing,impeller and base, install a 5/8 socket on pinion nut, take a pipe wrench in rag to middle of shaft and spin loose. I your going to reinstall these in a different housing make sure you shim it or gears will be trash in just a few outtings...
