I have a 1971 9.8. Ran great at high speed but died at the same speed predictably on deceleration. With cowling off, I repeated the rev-decelerate-die, until I noticed that tapping sound, indicative of an high voltage leak. One of the high voltage wires that ran around the engine under the flywheel had worn through and would short out when the deceleration caused the mechanism to move to just the right location. Get your engine to run, and listen when the engine stops firing.
