HI everyone,
I got this 1998 Mariner 2 strokes 90HP outboard engine. Every time I go the water I do the following:
1- pump the gas in
2- push the choke for 10 sec or more
3- lift up the lever
4- turn the key
The engine doesn't start straight away. It takes several times to start it. Once the engine is warm, it starts at the first time.
I play with the lever and the choke in different combinations or push the choke longer but the result is the same.
I used storage the boat with the engine vertically (to same some space). I am storing it now horizontal but I haven?t tried it once again.
Some guys have told me that is the normal behaviour of a 2 strokes engine. But I've seen other motors starting faster than mine (they are also 2 strokes).
Has anyone had this problem? How to fix it? Or is it like that.
Many thanks
Kerby
1- pump the gas in
4- turn the key
Many thanks
Kerby
