negativecold13
- Jan 15, 2014
- 20
I have most of this 1954 Mercury Mark 20 apart. Now I am to the lower unit. I have removed the Prop shaft, impeller housing, and mainshaft bolt. I thought after removing the mainshaft bolt, the drive gear would come on out. Worked around it with a screwdriver but no luck. Am I just being impatient or is there something else I need to do to get the mainshaft gear to drop? Thank you. Jesse
