Hey all, this is my first post. I've searched around but not much luck with finding my problem. Anyways, I have a 1976 mercury 200 (20hp) It has electric and pull start and runs great. Out of no where the throttle has jammed up and won't move. I believe I have pinpointed the area, its at the very top under the flywheel. I can remove that linkage and all works as should. So I removed flywheel and can't seem to see whats causing the jam. Any suggestions?
Thanks
Zac
Thanks
Zac
