jackofalltrades
- Apr 22, 2012
- 21
Hi fellows this is my first login to this forum. I have a 1988 mercury 150 xr4 black max that runs beautifully idling and full throttle out of water with water ears on lower foot. Will crank, time you hit the starter. Let it set for hour or two and overnight you will have to spray gas in carbs to get it to crank. Take it to the lake, go through the same starting procedure. When you push the throttle open it will bog down and smoke pretty heavily. Got 125psi on all cylinders, spark on all plugs and running about 6-7psi on fuel pump outlet. Pumped the bulb up last night and it was still tight this morning and clear inline filter was full. I did clean carbs, checked needle valves all working probably. I'm at wits end please sends some ideas thanks. I bought this boat from my cousin who bought the boat new. He fished in a private club where motors weren't allow to be cranked so this motor has very few hours on it. I have a lot of time invested in this boat. I separated the boat, stripped out everything down to hull and repaired everything. It took me a good year to do this under my garage. The wife is happy its over, but I'm ready to fish if I can get this labor of love running correctly thanks again
