Re: pee hole 35 hp mercury
[QUOTE said:
silverstreaker;4506614]I have a 35 hp mercury outboard, sn 0b394125; I am trying to determine how/when the water should come out of the pee hole. the original manual states that it will start coming out when you put the ears on. however, mine does not come on until it has run a couple of minutes. It does not have a thermostat, so wondering what is correct. impeller has been replaced. Sometime it actually starts steaming , then the pee hole will start working. as long as the pee hole works should I be concerned. It sometimes get hot enough that I cannot keep my hand on block. I think this is a 1990 or so engine.[/
QUOTE]
Silverstreaker.
I have to disagree with racerone. Your serial identifies your motor as a 1989. I have a 35HP Merc of the same year and it DOES NOT have a thermostat. The thermostat was done away with in the early 1980's for this block configuration, probably a reliability issue for Merc.
I had a the same experience as you describe above with another 35 Merc motor of this configuration. It turned out to be pieces of an old impeller caught in the water passage at the exhaust plate and floating around. Taking the exhaust plate off is tricky because there is danger of snapping off the bolts. When all is normal with your motor, the pee stream should begin within a few seconds of startup whether on muffs or in a barrel and the water will be only lukewarm.
If you did not personally change the impeller, then I would drop the lower unit first and look for trouble there.
John
The engine block should never be too hot to the touch.
