ib18
- Mar 2, 2013
- 489
Rebuilding Mercury 90 hp 2 cycles 3 cyclinders (1987) - 100, 100, 75 psi, third piston has low compression, motor cannot turn over, so tearing it down. Got stuck twice (1) could not get screws off - had to buy a deep wall wrench #10mm socket
(2) had to buy a flywheel puller.
mercury 90hp tear down part 3 - diy outboard motor rebuild - YouTube
give me your comments if you see something i did wrong. thanks.
I will load more videos as I continue to tear it down and rebuild this outboard motor
