I have an 1988 90hp mercury. There is a small plastic tube running from a fitting on the forward side of a collar near the top of the lower unit. The tube runs to the speedometer on the dash. This has got to be what causes the speedometer to register. The engine end of the tube doesn't appear to be open to the water. Can anyone explain how it works the speedometer. I also have the speed/temp paddle wheel sensor that runs to my Eagle sonar. Just can't figure out how the speedo works.
