G
Guest
Guest
Hi all, when I check compression I get 90 on top and about 80 at bottom but for the bottom cylinder I have pull like 12-15 times and break a sweat. Is that's normal? When I see people do it on YouTube they do it in 3-4 pulls with ease??? I also noticed the string got really tight to pull and once I pulled it out the compression went up?? What can that be is the engine bad?
