Re: 1986 mercury 150 xr2 blackmax charging upgrades
2 batteries will just give you more time between home chargings if your motors charging system isnt up to snuff as far as your load goes. Its a good safety measure if you use an isolation switch and you want to be able to start the motor and get home. First off , figure out your load and determine if you really need more charging. Some people do, especially if you run low speeds and crank that damn stereo frequently. 16 amp systems really dont come into their own until after 3000 ish but if you can't start the motor because your battery is dead thats pretty much a moot point.
If it were my motor I'd buy a core motor ( that one on S&F ) and part it out and keep the charging system. Worst case you'd have to buy a used late model cowl ( $200 ish ) or an aftermarket alien cowl (700 ish ). If you are buying an aftermarket alien cowl anyway and are blowing up your tax return and you dont want to hassle with parting a motor out then buy the Simon alternator kit ($600 ) . You'd have $900- $1300 in it by the time you were done.
If you arent familiar with what an alien cowl looks like ..here is what they look like. I'm not a huge fan of them but some people like that modern look.
