The plastic nipple that the hose that connects to on the sender unit on top of the remote oil tank broke today. I'm guess not enough oil getting to the engine or lose of suction/compression sounded the 3 low oil alarm beeps.
-Oil tank on engine is full of oil.
-Oil can be seen in the hose coming out of oil pump on motor.
-Motor will not turn over or run or do anything for that matter
So I know I need to replace the cap/sender unit on top of the remote oil tank and reconnect the hose.
Question is once I do this, how to I reset the alarm so that the motor will turn over again?
Thanks for your help in advance
