Attach is a picture of my outboard. If you look closely I have water coming from the hole that is located over the poppet. Should there be water coming from the hole?
Background: I ran in shallow water an kicked up a bunch of sand. I had to stick fishing line in the tell tale multiple times to get a strong stream. When I got home I connected the backwash port to engine but only had a weak flow. I then ran the engine on muffs and got a little stronger flow. To clear the engine of sand I used an air compressor to try to dislodge the sand. It worked and I now have a very strong flow on the muffs and the backwash attachment. I did use the air compressor in the poppet hole. I do not ever remember seeing water coming from that hole.
