marvin d miller
- Jan 22, 2014
- 1
I rescently noticed my tilt and trim did not work. I found the corroded red wire when it fell out of the wire harness under the dash and fixed it by connecting the wires together and not reconnecting them to the harness. The motor started fine, tilt worked fine and the motor ran fine until I turned it off. I tried to start it again and the starter would not disengage. I had to disconnect the positive wire from the battery to stop the starter. Each time I try to reconnect the positive wire to the battery the motor trys to start.
