40HP 2Cyl 5751264. Someone earlier has worked on this motor and replaced the stator with CDI 174-5255 and the Switch box with CDI 114-4911. Both of these appear to be correct. Bad and intermittent sparks led to checking the Trigger. Resistance measurements show the trigger to be defective. The Trigger fitted has three wires white and two browns. The drawings for this motor show the trigger with only two wires. Which is the correct trigger for this motor?
Any help would be appreciated.
