I have a 1984 35 HP Mercury Outboard. I need to remove the engine from the tilt assembly. I see the mounting bolts, but question the shift rod. If I remove the lower unit, does the shift rod come down with it, allowing the engine to be lifted up from the tilt bracket? Any helpful info would be much appreciated.
