88Glastron
- Nov 11, 2008
- 34
Last summer I bought a 1989 Mercury Blackmax to replace an early 80s Johnson. The Johnson overheated and I got a sweeper deal on the Blackmax which was incredibly clean and had great compression. I brought it home and ran it on a stand. The motor needed some maintenance done such as plugs, waterpump, carbs were rebuilt, so on. We did nothing to the ignition system. We transferred the harness and controls over to the boat and when we swapped the motor in we werent getting spark on any cylinder. The first thing we noticed was that there was a crack in one of the flywheel magnets so we replaced the flywheel. Still no spark. We followed the CDI troubleshooting chart and did the resistance checks on the components and everything tested sat as well as jumpering the safety lanyard. We tried disconnecting the harness and jumping the starter solenoid with still no spark. Next item replaced was the stator with no change.
At this point I would only be easter egging so I bring it in to a local shop and am told that they think either weak flywheel magnets or trigger assembly. I tell them that the flywheel was new and so they say trigger. I bought the trigger and installed it this afternoon with still no spark. I am at a loss now thinking the only other thing would be for both switch boxes to have gone out at the same time. I am looking for any input seeing as though the motor went from running on a stand to no spark once it was on the boat. Thanks in advance!
