Re: '65 merc 20hp fuel/oil mixture
The correct ratio is 50:1, or 1 pint of oil to 6 gallons of 87 octane gasoline. Use any TWC-3 rated 2 stroke oil. If you use ethanol enhanced fuel, keep an eye out for possible fuel line deterioration- ethanol can be erosive to some types of fuel lines. You may want to install a clear fuel filter- if the filter loads up with black stuff, it's time to replace the fuel lines.
