Happy New Year Y'all
I hope this is not a duplicate post because I thought I had posted already but maybe didn't click properly.
I have the textbook yucky whitish grey oil water emulsion dripping from the propeller front and back. It goes without saying that the propeller shaft seal is leaking and further confirmation when I drained the gear case.
I have the same whitish emulsion coming out of the Exhaust as well and it runs down the back of the leg.
My Questions
A.......Could the fact that it is coming out of the exhaust be directly related to the leaking prop shaft seal ? Or would you say I have more than one problem?
B.......Can the shaft seal be replaced without pulling the Lower End??
C........Do I need to flush out the lower end or do I just drain it and put fresh lube?
Thanks in Advance
My Questions
Thanks in Advance
