Imjus4u2nv
- Jun 10, 2013
- 57
I am in the process of fixing up my 90hp 1986 mercury Tower of Power, serial # 0A968445, model 1090726.
I had an issue with a cylinder overheating in the past, but still have good compression. I was running it on 5 out of 6 cylinders, but now after replacing switch packs have spark on all 6 cylinders. Before firing it up on all 6, I want to install a water temp gauge and a temp gauge.
I have read all the info here about them and have decided to do both.
I am having an issue finding the part (or a cheap part) for the temperature sender, that would go next to the top spark plug. According to mercury, factory replacement is part #87-96829A1.
Does anyone know what this part does? Is it just an overheat alarm, or can I actually plug it into the temp gauge I ordered (from Faria for $10 bucks https://faria-instruments.com/store/index-mart.php?cat=Water Temperature) and get a temp reading (I understand unless I overheat I will likely not get any temp reading). If it is a temp alarm, what do I hook it up to?
I was also wondering if i had to use part #87-96829A1, which runs for about $150-$300. I have looked up some other senders (thinking these may be for the water temp:
Faria 90401 (https://faria-instruments.com/products.php?calledGauge=4_temp)
Sierra 18-5896 (http://www.iboats.com/Mariner-Temperature-Senders/dm/view_id.270127)
Does anyone know if these will work instead as they are about $20 bucks.
As always any help is greatly appreciated (not sure if helpful but my engine does not have a head gasket, just a water jacket with two 'holes' for sensors).
