Re: 1982 4.5 mercury fuel line connector
You can run the hose from the tank to the fuel pump/carb straight and it will work fine, but will be a pain if you take the motor off the boat very often. It is best to leave it as it came unless the connectors are leaking air or have gone bad. Then you should replace them. JMO
Oldman570
