I have been running this engine for the last two seasons on a 50/1 ratio premix( gas/oil.) Three years ago the oil alarm started going off. I had a Merc mechanic check it out and he claimed the oiler gear was at fault and it was working only partially. I never disconnected the oiler. I notice that the 3 gallon oil tank does go down with engine use. Is there a problem not disconnecting the oiler?
I fill up the oil tank as it needs it. I know the engine must be running rich. It smokes on start up but does not smoke when the engine warms up. It runs great and has 375 original hours on it. (I bought this engine new.)
Can I just cut and plug the hose that goes from the oil reserve oil tank to the oil pump?
Please advise.
Sullmate
Please advise.
Sullmate
