Re: Kill switch working the wrong way round
Not trying to resurrect a dead thread, but in case anyone else ends up here due to a search on this issue... I ran into this same problem - purchased used control for my OB, but apparently it had been on an IO, as the switch was 'backward' for my OB - OB ran w/ switch in 'OFF' position, wouldn't run w/ switch in 'RUN' position. I pulled the control off again, removed the switch, and flipped the back side of the switch, then all was good. There at little tab/finger holder things on each side of the switch. Spread those, gently ease the back off - this will expose the 'guts'. Pay attention to which way the back is on to start with, flip it 180 degrees, and gently press it back together - making sure not to disturb the guts. (There's a spring w/ a contact plate on the end - be sure the contact plate doesn't come off of the spring...). Switch now works fine for my OB. Tried it on the OB-specific switch from my old unit (was all sun-beat, so didn't want to use that switch), and got the same reversed result (and was able to put it back to original again, too.) YMMV, but it saved my butt.
