Is low on power planing off? The 3.0L are bad about breaking reeds which it will run ok but be a little off on top end and a lazy low end. Check the basics first...compression, spark and if ok check fuel end (injectors & reeds).A DDT wont tell you much on this model.
From the manual:
COMPRESSION All Models ? Using a fully charged
battery, throttle shutters wide open
and cylinder block warm
90 ? 110 psi
(616.3 ? 753.5 kPa)
Variance between cylinders should not
exceed 15 psi (102.7 kPa)
Check your PM.
Gerry
