Re: Mercury 80 water pump change
You will have trouble aligning the shift shaft, if you reinstall the motor in forward. Turn the shift shaft CCW until it stops. Now use a cresent wrench to gently coax it CCW into neutral. Now set control to neutral. Tilt motor all the way up and lock it. Grease both splines. Is black plastic shift shaft block in place in the midsection? It should be.
Shove driveshaft into midsection until it stops. Now turn flywheel and push on gearcase. A small amount of turn will align the splines on the crankshaft and the driveshaft. Observe upper and lower shiftshaft. Use fingers or needlenose plier to align them. Now wiggle gearcase into position. It will be helpful to install a nut or two and using finger pressure only, wiggle and tighten nuts as you get the gearcase seated. Now tighten nuts, and install hidden bolt.
