90 HP Mercury two cycle compression is good but reliable mechanic tells me has a air leak (air leak test). Mechanic tells me it is good until it reaches the top. He doesn't have a bore scope!!! Does it need to be overhauled?The engine idles very well and the idle is set at lower then mfg specs, top end is always good and starts very well.
Mechanic thinks I shouldn't do anything now, considering how well it is running.....what do you guys think
I like to keep the motor as it is a perfect match for a Lund 1890 Pro V and I like the torgue it has for back trolling and out of the hole.
