seanymph85
- Nov 5, 2013
- 199
I had recently purchased this 1985 Sea Nymph boat with the above mentioned 1987 25 hp Mercury outboard. I was having trouble with the start/Off switch not shutting the motor off. Shortly after I discovered what I thought was just a loose black wire seemingly under a silver plate with 4 phillips head screws. I soon discovered this wire from the stop switch was just laying there loose under the plate and was not fastened to anything at all. I am attaching a picture to illustrate which wire was not connected to anything. I did a continuity test on the switch with it in the off position and found no problem with the continuity in that position. There was no result from attempting to test continuity with the switch in the run position but the motor started with the switch in the run position.
In any case I need to know if anybody knows where the single black only wire is supposed to be attached to.
Also hopefully it is okay to ask a second unrelated electrical question in this post. If not please let me know and I will post it separately. I noticed some "crud" around the spark plug wires where they go into the "coils". I tried to pull them out but there was apparently considerable build up on the ends where the fit into the coil as they would not come out. When I finally got one out the wire had come out of the connector and I had to pull what was remaining out of the "socket" with needle nose pliers. Two questions: Can the end of the wire be reconnected to the snap in connector that goes inside the coil and still work properly and what can I use to clean the crud out of "socket" in the "coil" that the end of the wire goes into? Can any kind of spray be used to help? Is there some kind of small round wire brush that can be used? My battery cable wire brush is to big for this.
