robert4488
- Nov 10, 2013
- 4
Not sure if this were I should post this. I was hoping someone on here could help me.
OK here it is, this only seems to happen after I use revers and then start going forward.What going is I start out going fine then as I give it more throttle just about to come up on plan the motor will try to jump in the boat with me and slam back down and die. most of the time it will do this once or twice and start working right, butt this last time out I could not get it to stop.
I was running in about ten feet of water so I was not hitting bottom. the only thing I can think is that the gate is not staying back and causing it to jump into revers, but everything is set to forward.
This is my first jet of any kind, I do not know what I need to look for.
