Hi, I have an issue with my Mercury 80 hp, I have replaced the spark plugs,CDI/Trigger and the stator and still no spark would the mercury switch (small blue thing with 2 wires one goes to earth) that's next to the switch box be the cause?.. or the rectifier?, hopefully a new battery might solve this? low battery power and slow turn over might cause the lack of spark?
Also the tilt and trim works, but stops half way lifting up, after putting power to the solenoid it will raise all the way, has no issue lowering down completely.. any ideas?
serial number is 8054064
