Ok so I have a 1989 Sea Ray (rebadged Mercury form what I understand) 100Hp outboard. I bought the boat/motor/trailer without know much about the condition of anything. It was a great deal even for just scrap metal.... So i guess i had to. Anyway I was told the that motor ran. The whole setup had been sitting for some time. The deck on the boat is all rotted out and the latest registration sticker on it is 2007. Although the seller mentioned they had the motor running this spring (I doubt it but who knows) I checked a few things here and there replaced a few oil injection lines and a fuel line (all cracked) and tried starting it up just to see where my starting point was. I turned it over by hand first and it seemed ok. So i connected a battery and tried starting.
After some messing with the started and quite a few cranks I got it to fire up. I only had it running for maybe 5-10 seconds then I **** it down. I didnt see any water coming out the pisser on it so i figured the impeller is bad. Nor surprised as im sure its been sitting dry for some time. So I went to remove the lower unit. Which shouldn't be that difficult.
I removed the 4 nuts and washer on the sides and the additional nut and washer up by the zinc. The lower unit doesnt really budge too much. I can rock it side to side just a tiny bit and see that its moving a little. But it wont really come down. I tried tapping with a rubber mallet lightly on the cavitaiton plates but that didn't do much and I don't want to break any of them.
Any suggestions on removing it? I was dark and cold so i decided to call it a night. I do have the forward gear selected by the way. Is there something else that holds it on? It almost feels like there is another fastener holding it.
Thanks for the help!
EDIT: Serial number is C171764
