1998 mercury 200 EFI 2stroke low idle
Status
Not open for further replies.
caravelle98
is it fairly easy to raise idle speed on this model? my engine dies when shifting in gear, a bummer when I get to the ramp and cant slow down the boat, thanks for any tip...
wired247
Re: 1998 mercury 200 EFI 2stroke low idle
Sure. If your idle stabilizer isnt hooked up you can just bump up your idle timing to increase the idle speed. Its a linkage adjustment. If your idle stabilizer is hooked up then its not doing its job. diconnect it and set your WOT timing and your idle timing and never reconnect it again.
BBDAD
I have a 1999 model with the same problem. Can you tell me where to find my idle stabilizer on the engine?
MOD EDIT: Please review the forum rule about posting to old threads and feel free to start a new thread with your specific information about the issue.
Status
