I have a 78 Mercury 1150 that I recently removed the lower unit on and replaced the impeller. I reinstalled it and when cranking the engine over the prop was spinning, obviously in gear.
I dropped the prop down today and was turning the shift rod back and forth on the lower unit. The rod moves freely back and forth just using my fingers.
As I was doing this I was turning the prop trying to find neutral. It ratchets clockwise and turns with some force counter clockwise.
No matter which direction I turn the shift rod the prop does the same thing.
I would appreciate any help with this.
