I've got a little Mariner 3.5 here, I think from the early to mid 80's. The tag has 642 S 032734 on it. Anyway, I just started it and it wasn't pumping water so I'm in the process of dropping the lower unit to replace the impeller. So far I've removed the 14mm nut and the 14mm bolt, and the little 8mm at the back near the exhaust port. It dropped down about 1/2" or so easily but stopped, I'm assuming because I have to address the shift linkage. Do I just disconnect the shift shaft through the adjustment window on the leg, where the clamp joining the two shaft sections is, under the rubber plug? Thanks in advance for any input.
